Игровая приставка от Sony Computer Entertainment, анонсированная 20 февраля 2013 года и выпущенная 15 ноября 2013.
1697вопросов Показать все
Ps4 freezes selcting user with error ce-36329-3
Ps4 freezes selecting user with error ce-36329-3 Then it will send the error to sony to then boot into the menu fine, apart from there will now be no menu sound. It seems to work fine after that.
I've tried a new hard drive, rebuilding data base, reinstalling and it still has the issue.
Update (08/24/2016)
New New info... It's not the themes that cause this.. The system music option does... If I turn off system music everythings works as it should, no error code on default theme, no freezing for a while for different themes or anything.. wtf
I'm going to make a new topic with the correct stuff now so maybe someone can help me, but I presume the system music is stored on the palystations actual storage, not the hard drive.
Update (08/23/2016)
New info:
It seems to be something to do with the themes/sounds? I go to change to a different theme and it crashes, I turn off the menu sounds and do it again, it's fine, I turn the sounds on and they all work?
No Idea if that was a one time thing either. This is so strange. Surely if the themes/sounds were corrupt they would get replaced when changing hard drive or reinstalling the os etc
After restarting (having auto log on left on as that seems to prevent the crash at start up) the sounds are gone again?
I really don't understand this is so strange.. wait..now there was a jingle and they randomly started working again.. Okay, even with the theme changed it still crashes when starting up without auto log in.. However it doesn't have an error code, it eventually loads with the sound working? Well menu sounds without the background music, that has never worked.
I am so confused
Now after putting the default theme back on it's got an error code again.. I guess the default theme is corrupt or something? Which is why it doesn't freeze on auto log in as it doesn't have to load the theme to select a user? idk, nor do I know how I could fix it cause I've reinstalled the software before
Это хороший вопрос?
Оценка 3
1 Комментарий
All I was doing look at Backgrounds for my System and it Crashes giving me the Code since Yesterday CE-36329-3 again that’s all I was doing. This is 5 Mont System I just got back in September of last Year not even a Year Old idk what to do if this keeps Happening and also it said that my memory was Full with it Wasn’t even close to that!
из
Добавить комментарий
4 Ответов
Наиболее полезный ответ
i did rebuild data based it works for me if still getting error. you need to perform initialeze PS4
still the same error the last resort might do the full reset.
https://www.errorsolutions.tech/error/ps...
Solution 3. Initialize PS4
Был ли этот ответ полезен?
Оценка 1
I hate it I mean what I did was leave it on and then the charge would just finish and it will turn off and from there u could put it in charge and hopefully it would work cause that's what I did with my brother's ps4
Оценка 0
1 Комментарий:
Something's wrong happened to my PlayStation is Frozen
из
Do you have any idea with this @tronicsfix It's a strange one
Оценка 0
2 Комментариев:
I saw this posted and have thought about it some and I'm not sure I've seen this exact issue out of the thousands I've repaired. It sounds almost like a hard drive issue but since you already replaced that it kind of rules it out.
I'm really not sure...it is definitely a strange one.
из
Yeah.. I'm not sure if I should keep this one for myself as the issues with it can be put around or sell it off cheap for someone who could deal with it. I don't think anything I could do could fix it unless a new update would fix it, but if that was the case I'd have thought changing hard drives and all would have sorted it.
из
If your PS4 is freezing and shut down suddenly, (but the white light still turn on) and when you start your ps4 again the error is appear (CE-36329-3)
Maybe the problem is the APU or the processor PS4, open your PS4 top housing (right) you will see 2 screw that hold the APU and the heatsink inside, try tighten 2 screw, if it doesn't work, try prop something on it, maybe a couple of coins or ring at the screw. Make sure you're fully tighten the screw.
Оценка 0
1 Комментарий:
I have the same problem my game was working just fine until I downloaded a couple of themes then the system leg started and had to re initialize the hard drive but I still have the leg in the hard drive and more errors then before would I have to replace Harv drive or rebuild the hard drive ?
из
Добавьте свой ответ
troymisti1 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 12
За всё время: 15,160
