The Acer Aspire V5-571-6891 laptop is for personal or small business use and was released in 2012. It is mostly black with a centered, silver logo.
3вопросов Показать все
laptop work but blank screen
when i try to boot it up it starts but the screen stays blank what are the possible solutions??
Это хороший вопрос?
Оценка 3
2 Комментариев
Can you see any mouse or anything on the screen ?
It might be very dull so you might have to really look for it.
из
Hi,
Does the screen 'light up' or stay black? If it stays 'black' try shining a torch at an angle close to the screen and see if you can see the desktop display once it has booted up. If so it could be a backlighting problem.
Try connecting an external monitor and see if there is a display on it when you boot up.
из
Добавить комментарий
3 Ответов
Выбранное решение
@tetzel , johann, Try hooking up an external monitor, if external monitor works probable laptop display issue, corrupt driver, bad connection on ribbon cable, bad display. If external monitor not working could be graphics card issue. Below link tells how to hook up external monitor to help trouble shoot your laptop, the 3rd link and other Acer forums on the net, addressing Blank/black screen talk about the Bios becomes corrupt and needing addressed. Good luck.
http://www.yumapk.com/how-to-connect-ace...
http://community.acer.com/t5/Legacy-Lapt...
http://www.tomsguide.com/answers/id-2221...
Был ли этот ответ полезен?
Оценка 4
Take out the battery. Press power button for a minute. Then put battery back in again and power up. Repeat couple of times if necessary.
Оценка 2
Possible that your memory needs to be re-seated
Оценка 1
Добавьте свой ответ
johann bayzil будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 9
За последние 30 дней: 22
За всё время: 9,974
