Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208вопросов Показать все
Getting Panic errors after coming out of sleep mode
I added a Samsung 500 GB EVO SSD using the ifixit.com kit.
I put the new drive in the new slot, but with the old cable, and put the original HDD back in its place but with the new cable. I performed a new install of El Capitan on the new drive.
I now seem to be encountering occasional kernel panics coming out of sleep mode. Has anyone else experienced this?
Это хороший вопрос?
Оценка 0
1 Комментарий:
Please double check your system info here. This is a Late 2012 mini correct?
из
Добавить комментарий
1 ответ
Configure the new equipment in the exact same place that the older parts were. If that doesn't work then you may have to use the older hard drive as your primary boot device.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Matthew McDonald будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 46
