Stops with an SD message
Washer stops right before rinse cycle with an SD message. I have to unplug to reset, therefore moving laundry to another washer to finish
Это хороший вопрос?
Это хороший вопрос?
Your code Sd is most likely related to 'slow drain', which can be the pump in the machine or the drain behind it. Check to be sure the drain is clearing quickly enough and if so, have the pump on the washer checked or remove from washer and clean it out. In the meantime, if you hit cancel and let it sit a bit then hit start, it should take right off and finish the cycle. Hope this helps!
Был ли этот ответ полезен?
needs to remove the pump from the bottom of the washer. what ever is causing this is in or around the pump. this can be done by tilting the machine to the rear. there are 2 clamps he can remove and remove the pump. check in the hoses and the pump itself.
За последние 24часов: 4
За последние 7 дней: 7
За последние 30 дней: 17
За всё время: 1,142
