6th generation Android smartphone designed by Google and manufactured by Huawei. Released October 2015.
Nexus 6P proximity sensor not working after changing LCD block
Due to water damage I had to replace my LCD block, since then everything works fine but the proximity sensor.
As a result, my screen turns black as soon as I make a phone call and I have no way to terminate the call (I now have enable the `use power button to end call` under the accessibility settings).
With the AndroSensor app, I can see that the proximity sensor reports `0 cm` all the time.
I suppose the issue comes from the repair I made, but I need directions on where exactly to look at inside the phone to diagnose/repair this.
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
I have this same problem. I thought the repairman (who I'll still visit to check), had put adhesive glue in between the proximity sensor, but now am starting to think it's definitely a dodgy aftermarket LCD digitizer.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Thomas будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 612
