Car charger and FM transmitter with a microphone from Xiaomi.
2вопросов Показать все
How to disassemble Xiaomi Roidmi 2S
Hello.
I am thinking of tweaking Xiaomi Roidmi 2S a bit because it has rather low quality microphone build in. I'd like to solder a 3.5 jack socket and that way attach a small directional external mic.
But I don't know how to disassemble this device :)
Can anyone help?
A perfection would be to put it step by step on YT.
Это хороший вопрос?
Оценка 5
Добавить комментарий
7 Ответов
Наиболее полезный ответ
Hi,
I already dismantled Roidmi , its easy but you need strong nails :)
from the up side the USP cover, i inserted my nail between the USB cover and Roidmi body then carefully pull it out from one side, then you need to go around to pull the other side clip.
The problem that my Roidmi not working i couldn't manage to know what is the problem.
If you need pictures just let me know.
Regards,
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Yes, please. I would be very helpful
из
Yes, please upload some pictures :)
из
Hello Don, Were you able to disassemble it? I'm trying to do the same thing.
Оценка 0
Hi.
Unfortunatelly not. I think I'm gonna buy a cheapest version of Roidmi and brut-force disassemble it.
Roidmi 2S is to nice looking to crack it open... ;)
Оценка 0
Isn't the Xiaomi Roidmi 2S a bluetooth FM transmitter for your car? It doesn't have a mic? You sure you are talking about the same device?
Оценка 0
2 Комментариев:
Xiaomi Roidmi 2S Features:
1. Upgrade new Music Bluetooth Car Charger, compatible with iOS, Android, the performance is more powerful.
2. Wirelessly transmit, intelligent connection, wirelessly transmit call and music from Bluetooth phone to the car FM stereo system.
3. MIC version car charger, safe and convenient, Bluetooth hands-free calls, enjoy your safe driving, you will not miss calls any more.
4. Voice recognition, cool and intimate, turn on voice recognition function, just say “Next song”, “tell me a joke”, “tell me the weather”, you’ll get it. (Note: Chinese version only support Chinese)
5. Fully upgraded APP, you'll constantly be surprised ! Perfectly support Android, iOS system, monitor battery voltage,inquiry traffic violation. More practical, fully upgraded APP system, you will enjoy using it with the upgraded APP. New features, waiting for you.
6. Fully improve the quality of music, empty radio station scanning, intelligent background noise reduction.
из
We have a mic on roidmi 2s, but we'd like to solder a 3.5 jack socket instead microphone. Just for extension
из
Hello Everyone, I have disassembled the Roidme 2S and I have uploaded the highest quality photos along with one video I could take for you guys.
https://www.dropbox.com/sh/d63s2ju16l45c...
I can't figure out where the microphone located on the chip. If any of you can figure it out please do reply.
Thank you,
Оценка 0
4 Комментариев:
I may be wrong, but I'm afraid you do not have a microphone. Should be at the top. Next to the usb socket. Do you have a small hole in the cover?
из
yes, you are right, it should be close to the front part and behind the holes, can you provide clear and zoom in picutre of what is around USB connector and at the back, also look care fully inside usb connector, show us the back of the cover you removed
из
Could you please describe step by step, very detailed, how you disassembled this device?
Pictures are cool but they actually don't show us how to start and not damage roidmi
из
Guys have a look at the 3 videos I uploaded for you on the same link. It will answer all of your questions :)
из
@yrsengar
I'm not sure whether you disamble Roidmi 2s.
As you can see on my link it's clearly visible microphone "hole".
On your photos&film I cannot see similar part...
http://www.everbuying.net/product1178867...
Оценка 0
2 Комментариев:
Hello Michal,
It is Roidmi 2s. You are confused because the images you are looking at are of the internal parts. I have created 3 videos for you guys, showing its outer shell along with internal parts. These videos should give you a really good idea on how it is assembled and how to disassemble it.
In my experience, I do not think that you can disassemble it witout doing any harm to its outer shell. As you can see in the video I did manage to open it but there is quite a bit of damage to the front cover but I am ok with it because it does not affect its functionality in any way and I can stick it back with some super glue.
I have moved on from modifying the Roidme 2s and installed a music system in my car with performs way better. It was a mission as my car is a bit unique but I did it at last.
Good luck
из
Hi, if there is no pressure/humidity sensor in this device the microphone is located on the rear side of the front PCB, where the USB sockets are soldered (see IMG_3697.JPG). Maybe it is possible to desolder it, solder copper wires to the board and either connect a new microphone to it or the original one just to put it in a better position.
Cheers,
Helge.
из
Hello everyone,
Is anyone resolve this problem and put a new (longer) microphone to this Roidmi 2s ?
Thanks
Оценка 0
Добавьте свой ответ
Don Andress будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 14
За последние 30 дней: 27
За всё время: 5,749
