27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
What is causing barely seen vertical line
I have a thunderbolt display that recently showing a barely seen vertical line (see picture) some kind of noise, there is nothing else wrong, neither color or picture.
I was wondering if its noise from power supply or logic board or T-CON board, the lcd is LM270WQ1-SDB3.
I dont have a schematics and can not find it either by googling (checking probe point with oscilloscope ).
link to picture:
https://s9.postimg.org/6aczv1z2n/DSC_000...
thanks in advance.
Ted :)
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
The ribbon wire inside of the monitor may need to be "reseated". Basically unplugged and plugged back in. Before you go through all that trouble try to eliminate ALL electro-magnetic sources of interference. If it persists, it may be the ribbon wire.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
How about a link to how to do that?
из
http://google.com <-- try this one, John. :)
из
Добавьте свой ответ
ted lindsay будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 507
