Open the HP 15ac137cl Case
How do I remove the back cover of the HP 15ac13cl so that I can replace the hard drive?
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
I thought I had marked this issues as solved. Thank you so much to everyone that helped!! There were two hidden screws underneath the rubber pads near the monitor's hinge. Once they were removed, it came right open.
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
HP has a link to their repair manual PDF here:
http://h10032.www1.hp.com/ctg/Manual/c04...
Looks like there's a Service Door that may help.
Оценка 1
1 Комментарий:
Thank you! I'll read a little deeper since this particular model doesn't have any service doors or access panels to anything. There might be a clue in there somewhere tho!
из
Добавьте свой ответ
Sandee будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 217
