Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
450вопросов Показать все
Are Ipad Air 2 wifi version speakers compatible with the cell version?
Are speakers in the store that are available for the Ipad Air 2 Wifi version compatible with the cellular version as well? Common sense says they would be but I wanted to check to make sure before I tore down my iPad
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
The speakers should be the same, as there is no reason why Apple should make different models of the speakers for the cell and wifi iPads. If you can, compare pictures/serial numbers and see if you spot any differences, but I can say for sure that they shouldn't be any different.
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
Ok thanks. I was just making sure and I wouldn't think they would change anything
из
*usually* iPad parts don't change between 4G and wifi. The only things I know of for sure are the obvious: the rear case, antennas and main board. Other than that, they are all interchangeable.
из
Добавьте свой ответ
Tyler Vaught будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 38
