Why my ipad mini4 no sound?
how can i fix my ipad mini sounds?
Это хороший вопрос?
Make sure the device isn't muted. Check the rocker switch on the side and also press volume up. If that doesn't work, go into settings > sound and make sure everything is set right there.
Report back if you still have issues.
Был ли этот ответ полезен?
still no sounds
has it been dropped or had any water damage?
Still no sound. I'm typing this with my volume up and I can't hear the sound.
Still no sound..is it broke down
iPad mini 4 doesn't have a rocker switch.
You can go to settings>General >reset>reset all settings. That should fix the no sound problem.
За последние 24часов: 4
За последние 7 дней: 11
За последние 30 дней: 19
За всё время: 18,799
