Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
227вопросов Показать все
Вопрос закрыт
Little but not real pulse
4th Gen iPod. What I thought was a simple battery issue I've come to believe is more the USB dock connection. I've replaced the battery. Same issue exists. The iPod runs out of juice. That's not to say this hasn't worked recently. But connecting it to computer needs constant wiggling of the dock connector. After that it seems it rarely remains connected. Does one replace that piece of the iPod? This was most likely damaged using a stand-alone speaker system which the iPod stood on.
Это хороший вопрос?
Оценка 0
1 Комментарий
Great. Thanks. This will be the last thing I try as logic board is 1/4 way to new ipod.
If you broke it down %-wise, what are you paying for with iPod? The hard drive? The hardware surrounding it? The Apple name?
из
Добавить комментарий
1 ответ
Выбранное решение
No, the dock connector is soldered down onto the logic board (see this photo); you'll have to replace the whole logic board.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
+ nice research
из
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 736
