A guitar shaped controller for Guitar Hero III of the Guitar Hero video game franchise.
29вопросов Показать все
when I push the yellow button both yellow and blue are activated
how can i fix this isssue
Это хороший вопрос?
Оценка 1
1 Комментарий:
Did you find a fix for this?
из
Добавить комментарий
2 Ответов
Hola heyhoy52 ¿cómo estás?, I'm from Colombia and I hope your okay, first of all happy new Solar Cycle.
Probably what's causing your issue is the connection between the cables and the PCB (the board), so I strongly recommend you to chek this, look at the picture please. If it's necessary cut the first 5 or 8 millimeters of the cable and solder to the PCB again.
Был ли этот ответ полезен?
Оценка 0
First, check if the PCB board inside the neck has been worked on before. It sounds like someone tried to fix it previously and their soldering bridged between the two contact points. Check both ends of the wires for soldering that bridges two connections.
Оценка 0
1 Комментарий:
I am having this exact problem. Nobody seems to know what to do
из
Добавьте свой ответ
heyjoy52 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 2,058
