Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
iPhone 6 keeps searching for signal
okay so, my iphone bended exactly one year ago.... and ever since it has been searching for signal.... sometimes i was lucky and the service came on, for like a day or two, but then it started searching all over again....
I have tried everything by now exept switching the internal antenna.
i have searched the web, for days, and i have found a lot of solutions, but none which worked for me.
any suggestions? i'll do anything by now....
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
Thanks for Answering, although this didn't work..... not sure what I need to get repaired, if I'm quite honest
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I guess your antenna needs replacement, it looks like the bending caused some issues with the signal, stop by an apple store and ask an employee
Greetings!
из
I work at a Technical services, and I've encountered this problem quite often.
usually you need to go to Settings- Generals- Time and Date, Then uncheck automatic search.
make sure your wifi is connected and make sure you've turned on automatic search again.
hope this helps, if it doesn't then you need to repair your iphone
Оценка 0
Добавьте свой ответ
jelikofer будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 351
