Hi @Offroadhen,
Can you use the controls on the back of the TV to change the input to another source and see if that works.
If it doesn't select the Menu button and see if the menu screen appears. Go to Menu Setup and see if there is a factory reset option or a Firmware update option.
Click on image below to enlarge and view.
Hi @Offroadhen
If you get a chance to do it, try updating the firmware for the TV.
Here is a link to the page. There is a firmware download link on the page (E50 Firmware Update, the download is approx. 73Mb) and there is also a link there for the download and install instructions.
http://shop.panasonic.com/support-only/T...
I have found some information not particular to your model but to Panasonic that there is a firmware fix that solved what is known to cause the problem of starting up and then shutting down with a slow blinking light. Not saying that this is your problem but at this stage it won't hurt to try.
Here is what in part it says:
.......The cause of the problem is due to the uneven distribution of mercury in the led backlight, which when cold, makes the start sequence slow down. The issue is resolved by changing or updating the Firmware package.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
2
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
9 Комментариев
Hi, As your screen seems to be working given the pictures being shown in the video you posted I'm wondering if you have a software problem. It also shows a no input signal message in the video. Have you got anything connected to any of the inputs at all? Have you tried switching to different inputs or doesn't the remote control function either? If the remote control works does pressing the menu button on the remote bring up a screen?
из jayeff
Offroadhen does the onboard menu show when you use the remote or the buttons?
из oldturkey03
@jayeff @oldturkey03
I had my PS3 connected to the input and it displayed momentary. I don't have the original remote for this TV. I tried using another remote from another Panasonic and some of the controls might work but, screen won't stay on long enough to show that they really do
из Offroadhen
@jayeff
I pressed the menu button and the menu showed until the tv turned off. I could not get through the setting fast enough to be able to find a factory reset
из Offroadhen
Still no screen. I'd like to try the firmware update which needs to connected to the internet, right? I have NO Remote control so, this makes your advise difficult to do. My scree screen disappears after 4-5 seconds. Any other suggestions?
из Offroadhen
Показать 4 больше комментариев
