I ran out of gas
I ran out of gas in my 2006 saturn ion. I have replaced the fuel filter and spark plugs. I have cleaned the fuel pump and it is working. But my check engine light is flashing and still does not run like it should.
Это хороший вопрос?
1 Комментарий
Hi, If you are in the USA take your car to an AutoZone store. They will do a OBDII scan of your car using a scantool, for free. That way you will know what the fault codes are and the most likely cause of the problem and you can proceed from there.
из jayeff
