THINKPAD T520: Top Tier Performance and Portability.
17вопросов Показать все
On startup it beeps and has blackscreen. help!
So when i start my computer it has a black screen and beeps, its 3 beeps followed by another 3 then followed by 1. I suppose its like a RAM issue from what ive read but i dont know if the solutions apply to my computer. Its my school comp btw so need it fixed ASAP :) (not very technical)
Это хороший вопрос?
Оценка 2
1 Комментарий
2 beeps pause 1 beep then repeats
из
Добавить комментарий
4 Ответов
Выбранное решение
Trak, you can try reseating(remove and reinsert in case of bad connection) the Ram/memory in your computer to see if that fixes the fault your having. I will post a link on how you access the Ram/memory to enable you to try this. Good luck .
http://www.storagereview.com/lenovo_thin...
Был ли этот ответ полезен?
Оценка 5
6 Комментариев:
I'm having the same issue as the original post but it happens after i try and install a new trackpad. The error only happens while the trackpad is plugged in though
из
@oatmeal0719
Have you tried resetting the BIOS?
из
@aactech
I have not. I'm not entirely sure how to reset the BIOS from a black screen, or if resetting it would work before putting the trackpad back in
из
@oatmeal0719
Take out main battery. Discharge power by pressing On/Off button. Open case and unplug the CMOS (they call it "backup battery here). Here's the diagram from the manual.
https://support.lenovo.com/nz/en/solutio...
or download entire manual:
https://www.manualslib.com/download/4933...
из
I tried everything for the above comments and my screen remain black and the beeping continues. The power light flash and the "caps lock" light is on. I don't know how to fix this. Please give light
из
Показать 1 больше комментариев
This should be a question but https://support.lenovo.com/us/en/solutio... those are all the codes
Оценка 0
John hall is right about the track pad wire my track pad comes off easily and is snapped off the wire. I tucked the wire into the laptop and it started touching something I’m guessing metal which caused it to short circuit I think. I just had the get out the wire.
Оценка 0
I have a Lenovo X1 Extreme Gen 1.
Got the 0282 beep. Memory module or system board error. I tried swapping out the memory didn't work. System board was above my pay grade. I'm glad I found this thread because I disconnected the touchpad and it works now. Thanks John Hall et al.
Оценка 0
Добавьте свой ответ
Traktorsven будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 22
За последние 7 дней: 125
За последние 30 дней: 517
За всё время: 65,073
