14 Megapixel camera. Has 12x Optical zoom, 48x Digital zoom, OIS, HD video with Stereo microphones and autofocus. Comes in Red or Black. This camera supports the following memory cards: SD/SDHC/SDXC/EyeFi (full support).
18вопросов Показать все
Lens cover won't open anymore
My lens cover won't seem to open and close like it used to. This prevents me from taking pictures quickly because I always have to check to see if the lens cover is open, or not. I can force it open by hand, but wonder what I need to do to fix this problem?
Это хороший вопрос?
Оценка 0
1 Комментарий
Mine does the same, but it doesn't seem like it's the springs since when I turn off the camera, the lens cover closes by itself.
из
Добавить комментарий
1 ответ
Выбранное решение
It sounds like the springs in your lens cover may be out. If the lens stay open after you force them open, and don't bounce back into place, then it's most likely that your springs are broken or disconnected from the lens. You'll have to open up your camera to make sure! You may either have to replace the springs or simply reattach them to the lens cover.
Please see the troubleshooting page for more information.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Sam Blanton будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 16
За последние 30 дней: 31
За всё время: 2,332
