I've seen it done but don't recommended.
Reason why they don't just sell the digitizer(the glass).
But yes it only adhesive that you have to remove carefully.
If your removing a digitizer from a defect, water damage LCD make sure that the ribbon isn't damage or burned at the ribbons ends.
If they're good, then remove the adhesive carefully, do not damage the bottom of the digitizer(there's an invisible web to the naked eye). When removing the adhesive, I recommend not to remove all the adhesive from the glass.
Why because your going to compress it together and you need to know if your mounting it correct.
Forgot to mention use a x-acto blade #11.
Hope that helps. Good luck with that.
But if anyone know where just to get the digitizer(the glass). Let us know.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
