Полная разборка и инструкции по замене для оригинального iPhone, iPhone 3G, iPhone 3GS, iPhone 4, iPhone 4s, iPhone 5, iPhone 5c, iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s и iPhone 6s Plus.
36471вопросов Показать все
Unexpected error 9 iTunes
I have an iPhone with cracked glass that don't power-on (even backlight).
If i simple connect to iTunes, i receive the message that a restoring is required (recovery mode, i can see the IMEI).
I've tried restoring it in DFU, recovery mode, and both ipsw firmware iOS 9 and 10, all with the same result - iTunes keeps throwing error 9
Also noticed that if i keep the iPhone just connected to the PC (without doing anything), it will disconnect and reconnect automatically every certain amount of time.
I've also tried this solution: How to fix iTunes error 9
With those results:
- Reiboot (http://www.tenorshare.com/products/reibo...) = Stuck at "Exiting from recovery mode, please wait..."
- i4Tools (http://www.i4.cn/) v.7.10 = Error at 15% (Step: NORData)
Any ideas/help would be appreciated.
Thanks in advance.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Its NAND IC fault>>>
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Luca Pastrani будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 614
