Correct time cannot be set on my Fitbit
I don't know how to change the time on my Fitbit Zip
Это хороший вопрос?
Это хороший вопрос?
Hi Marg,
You have to change your settings on Fitbit's website:
-Log in to your fitbit.com dashboard and click the gear icon in the top right corner.
-Click Settings.
-Scroll to the bottom of the Personal Info page and modify your timezone.
-After saving your changes, force sync your tracker: Click the Fitbit Connect icon located near the date and time on your computer. Click Sync Now.
Hope that helps!
Был ли этот ответ полезен?
I have tried all the suggestions and I still can't get the time right.
Is there a video showing step by step how to fix clock
How do I change the device my fitbit was originally set up to? I no longer have that computer and I need to reset the time
i went to the app on my phone,went to advance settings ,turned of auto time zone ,selected my time zone ,ie Melbourne ,went out of settings to dashboard tap the blaze clock top right corner then tap sync now and all fixed
Hey guys. To fix your time zone:
1. Go to Account -> Advanced Settings
2. Turn off automatic time zone
3. Select random time zone
4. Sync
5. Go back to Account -> Advanced Settings
6. Select your correct time zone
7. Sync
Ta-da!
I don't have the computer I set up my fitbit on. Recently got a new on. How do I sync it to the new one?
Frank, you're the King!
ok. I'm getting better. where is Sync?
My ap is still searching for the Fitbit. It found it, then said to put in the number displayed on my app. I did that and it’s still searching. It’s been 15 min. The Fitbit doesn’t sync to my phone. It hasn’t worked since the first week. So I can’t track anything but the rest still works. So how do I get my time corrected on my Fitbit?
I did all that and the time on my fitbit alta hr on my hand is still wrong
Hi All
I went to the app on my phone,went to advance settings ,turned off auto time zone ,selected my time zone ,ie Melbourne ,went out of settings to dashboard tap the blaze clock top right corner then tap sync now and all fixed
I tried this several times, still doesn't work,
Same here ... terrible !
You have to turn off auto time zone on phone, select a city with your correct time zone, then, on phone, tap the Fitbit icon, then turn on auto time zone and select a city with your time zone.
Tried and tried time keeps revert back to Los Angeles given up
Go on to your account profile and view personal go into location and make sure it’s on then save it sorted out both my surge and ionic times are correct now
App Settings.
Turn off the Automatic time zone option. Tap Select time zone and choose the correct time zone. Sync your Fitbit device.
Regards,
Will
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 23
За всё время: 279,024
15 Комментариев
set time on fitbit
из robert walker
I don't know what is my fitbits name and I can't set the time
из cool kidpaige
Correct the time on my Fitbit
из Kathleen barbara Fisher
There is not anything visible. Satting in mobile
из Prakashchandra Mehta
I can't correct the time on my fitbit watch
из Stella Ihuoma
Показать 10 больше комментариев
