Why does my phone say android starting but wont load
my phone keeps say Android starting / starting apps for the past 24hrs . I have done everything even master reset and it still doing the same thing . Can you please help me fix this problem . also the problem start right after metro pcs made an update on it
Это хороший вопрос?
Оценка 1
2 Комментариев:
sounds like the boot loader has become corrupted and is corrupting the OS on restore, you will most likely need to use a computer and the ADB to redo the boot loader and OS.
Good Luck
из
Same thing happened to my metro pcs phone after they updated now phone is just stuck on updating android apps frustrating
из
Добавить комментарий
3 Ответов
a factory reset from recovery should fix this. If not flash the stock rom. You can factory reset by holding power and volume up or down(depending on device) then selecting wipe data in recovery mode.
Был ли этот ответ полезен?
Оценка 0
What do I do if my phone is stuck on the Android loading screen?
Press and hold both the “Power” and “Volume Down” buttons. Do this for about 20 seconds or until the device restarts again. This will often clear the memory, and cause the device to start normally.
Оценка 0
Instal Nova launcer from Google play and you get new funkcionalnal fast fon... In my case Alcatel 1c was reborn from "android now starting" on main screen.
Оценка 0
Добавьте свой ответ
Dwana будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 3,408
