LCD Replacement, green snow and flash
I bough a new screen replacement from amazon to replace my cracked one. After installation, the screen mostly remains blank. If I manipulate the phone by applying pressure, sometimes I can get greenish snow (static) to appear on the screen followed by a green flash, and then the screen is black again.
Is there a connector that may be loose causing this problem, or is it an RMA? I have tried reconnecting everything, but it doesn't seem to solve the issue. I re-assembled the phone with the original parts, and it is working as before, so I know I didn't damage my parts. Thanks for any help you may be able to give.
Это хороший вопрос?
Счет 0
Добавить комментарий
