iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
iPod Classic content missing
Hello, My Ipod Classic is now not showing any playlists, songs, albums etc. It is just showing "No Playlists" "No Songs" "No albums" etc. I previously had dozens of playlists installed and thousands of songs but now I am getting the "No playlists" "No Songs" etc. So it is acting like all the content of the Ipod has been completely erased or deleted, however when I go into "settings" It shows me that there is 73 GB of spaced used out of 160.. so it appears the playlists and songs are still on the device however I can't get them to appear. Can you help and advise? Thank you
Это хороший вопрос?
Счет 1
1 Комментарий
@ipodclassic does iTunes still recognize your iPod? What does iTunes tell you about the contents?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Try a quick restore:
  1. Slide the Hold switch to the locked position and then slide it to unlocked again.
  2. Press and hold the Menu and Center (or Select) buttons together until you see the Apple logo (about six to eight seconds). You might need to repeat this step.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
Quick restore is useless... everything is in ipod, but it all became invisible for ipod. Do you have any another solution of this problem?
из
Brilliant so easy, my wife very happy that her music has been recovered.
из
Sounds like a software problem. This can probably be fixed with a restore. Plug your iPod into iTunes, then press “Restore”. This will erase your iPod and then put a new copy of the iPod software on it, making it the same as it was when you got it.
Счет 0
1 Комментарий:
iTunes does not see the iPod. Any other way to "restore"?
из
Добавьте свой ответ
Ipod Classic буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 4,827
