1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142вопросов Показать все
Вопрос закрыт
CPU Upgraded, do I need to reinstall OS X?
I have just upgraded my core solo to a core 2 duo (Thanks Guys!). Coming from the Windows world, I know that I would need to reinstall my OS otherwise funny things happen. Should I re-install OS X at this point ? (Been upgraded from 10.4 through 10.6.4, so it maybe time anyways...)
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
I don't think so. I've installed hard drives from diierent machines and different systems into other Macs and as long as the Mac could operate under that system, I've never had a problem.
Был ли этот ответ полезен?
Оценка 4
4 Комментариев:
works for me +
из
yup, no need to reinstall.
из
The answer is: Yes, you should do a clean reinstall. After reinstallation, things like 64-Bit apps, additional app speed (Handbrake, which is my main benchmarking app as it can turn any CPU into a drooling mess) and stability increased. Now, the issue of was the CPU upgrade the cause or the symptom, I do not know. I suspect it was a little of both.
из
I just did this upgrade and will let you know if I have any problems. But to be safe, it couldn't hurt.
из
it's not be necessary to reinstall
(but you can passe in 64 bits if it's possible for the CPU
Оценка 0
1 Комментарий:
Due to what I was upgrading from, the answer is YES. I went from core solos to core 2 duos. GCD handles differently w/out the multiple cores present if it installs at all. Anyways, I will agree that in most cases the answer is a resounding no. Except I am/was in an edge case where the answer is yes.
Thanks,
из
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 1,614
