The sedan version of the compact Toyota known as the Echo, Yaris, or Platz depending on the market. The hatchback version of the Echo/Yaris is known as the Toyota Vitz.
What type of 02 sensor do I need?
2003 echo
I need to replace my 02 sensor, the mechanic took mine out and said I needed to go buy a new sensor. I was told that there are 2 different types of 02 sensors, a 3 wire and a 4 wire sensor.
4 cylinder, 5 speed, 4 door, automatic.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
Выбранное решение
Your local parts store should know. Your mechanic took it out, what did he do with it? He knows which one it is. Ask for your part back or look.
Here's the four wire: http://www.carparts.com/details/Toyota/E...
Here's the three wire: http://www.carparts.com/details/Toyota/E...
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
mayer, question for you, who decides chosen solution to an answer and why would some one choose some ones question as the chosen solution/accepted answer when I was the only one that posted an answer. I have noticed this a few times. example of what I am mentioning in link below. Thanks for your response in advance.
Starter relay location under dash
из
@lpfaff1 On this one Dawn, the OP, posted her own answer (that was actually a comment). The OP of a question can accept any answer. Looks like she likes herself more than you ;-) I have left her a comment on this.
You can vote on any question and also vote via moderation to vote up an answer for acceptance or several other options. We get so little voting that this seldom happens (just lack of participation).
Moderators can accept or kick a question off with just our vote,
из
The continuing advancement in technology has brought many changes to the structure of today's automobiles. While vehicles of yesteryears were equipped with extremely large and unrefined engines, new vehicles are equipped with smaller engines that produces more power at a refinement level way above the engines of the past. BUY OEM PARTS FOR CHEAP
Оценка 0
Добавьте свой ответ
Joe Thibault будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 251
