Repair information and guides for MacBook Pro models with 13" displays.
9745вопросов Показать все
Accidentally Erased Hard Drive...
Posting for a friend - although I've also done this in the past:
I meant to run First Aid on a client's internal drive, while booted from a different drive, but instead I accidentally erased the internal drive (!!!).
I have Data Rescue, and am running the Deleted Files scan now. But from my understanding, it does not recover any of the original directory structure or filenames.
I have not written any data to it - the only thing I've done since the erasure is initiated the Deleted Files scan.
Do I have any options for restoring the client's machine to its pre-erased state?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
At this point your best option is to run a recovery application such as the one you are currently running. I am not aware of anyway to "unerase" the drive. Given the drive has not been booted and a secure erase was not performed most of the files should be on the drive. Some recovery programs will recover the name as well.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Colin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 76
