Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
unable to turn on touch id
Took an ipad mini 3 on partial trade for an ipad 2 i had fixed. The front was smashed, Replaced the dizitizer, home button and screen. Everything works great but every time you turn it on it says "unable to turn on touch ID" i assume this is because the home button was replaced. I don't care about the touch ID at all. Is there a way to get it not to display the message?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
You replaced the home button, that's it. Nobody can make it work again.
This could be an error message in iOS 10, apple has found a new way to annoy people.
Был ли этот ответ полезен?
Оценка 1
Have you tried disabling touch id in settings?
Оценка 0
1 Комментарий:
Touch Id is Disabled in settings. if you try to enable it the message pops up.
Everything else works fine, it just pops up that message every time you turn it on
из
Добавьте свой ответ
mikebarkas будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 281
