Laptops manufactured by Dynabook (formerly Toshiba). Toshiba has since transferred 100% ownership of the laptop business to Sharp.
1272вопросов Показать все
but the screen is black
Please help, My Laptop (Toshiba Satellite L75D) turns on, indicator lights on, fan is running, but the screen is black. I tried all the instructions but nothing worked. Any idea how to fix this?
Это хороший вопрос?
Оценка 1
1 Комментарий
Hi, Try connecting an external monitor and see if there is a display on it.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
first you must do some tests before like changing the ram connect to external lcd then i will told you
Был ли этот ответ полезен?
Оценка 1
Hey, as the previous commenter suggests, if your laptop supports external display you can plug it into a monitor or a TV to at least see if its the Graphics chip OR the screen itself that's flaking out on you.
If the display (HDMI/VGA/Display Port etc) sends a signal to the external display you have a problem with the LED/LCD in the laptop.
If you don't, then there is likely a good chance the issue is with your graphics chip, or something else.
I've seen the display issue being anything from a kinked cable, to a blown backlight. Most times its approximately $100-150 fix depending on where you source the parts, and who puts it in. (I've seen big box stores charge upwards of $300-600 depending on screen size)
Оценка 0
Добавьте свой ответ
Running Guy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 113
