Released by Samsung in March 2016. Model SM-G930.
425вопросов Показать все
Bloated battery after the phone dropped
Dear friends,
Today I recieved a Samsung Glaxy s7 with a swollen/bloated battery. He said it happend after he dropped the phone. They tried to put a new battery in, but the phone still didn't powered on. Do you guys have any solutions?
Это хороший вопрос?
Оценка 1
1 Комментарий
I also having problem with my Samsung Galaxy S7 Edge though. After it dropped, the battery bloated and the screen gone green eventually unusable. So I had to change the battery, the same thing it fell and bloating slowly. I'm afraid it might burst. what to do?
из
Добавить комментарий
2 Ответов
Выбранное решение
Question, statement and (hopefully) a solution:
Question: Who is "they?"
Statement: The most likely reason for bad batteries is because a small piece of foil ruptures with shock and causes the two electrodes of the battery to touch, overheat, and create problems (i.e. exploding).
Solution: Unless you're really comfortable working with at-risk lithium batteries, I wouldn't work with it, and would carefully dispose of the battery properly. If the battery bends a fraction of a millimeter too much, you could rupture that same small piece of foil and start a chemical fire or explosion. This problem was only intensified with the S7 Edge as that foil simply failed too easily. You can get a new battery from a reputable brand like iFixit and use their replacement guides. You may need to also replace the screen adhesive.
Galaxy S7 Battery
Galaxy S7 Battery Изображение
Продукт
Galaxy S7 Battery
$19.99
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
They = another repair guy. He said that they tried a new battery but it didn't worked. However I don't even believe they even tried to remove the battery.
из
Also screen adhesive? The phone it's back is opened I will add some pictures
из
This is what the phone looks like atm
Оценка 0
8 Комментариев:
Do you think it's too dangerous to replace the battery @skimmilk05 ?
из
Can someone help me?
из
Again, if you feel comfortable doing it, and think you can do it SAFELY, then it's your choice, but I can't gauge your abilities or comfort level dealing with these things. Personally, I'd go for it in a safe environment (i.e. outside with a fire extinguisher) if it were my phone, otherwise I'd go to Samsung (say if it were someone elses). I'm not too comfortable with damaged batteries.
из
I tell you the whole story I know right now. He bought the phone, he dropped the phone. Someone else repaired it, battery was swolen. Went to another store, phone didn't turned one anymore/didn't charged anymore. I think it also could be the charging port
из
It also went to Samsung they refused to repair it, rediculous isn't it?
из
Показать 3 больше комментариев
Добавьте свой ответ
Stijn Helmonds будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 7
За последние 30 дней: 19
За всё время: 4,399
