Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
1004вопросов Показать все
MacBook Pro not turning on with or without battery
So, Macbook Pro 2009, 3.06ghz, duo 8gb, 17"
Not turning on when new battery in, or out, power board seems to be working, does the same with old battery still with some juice in it.
If I keep trying over and over it comes on and stays on until I try a restart or shutdown, sleeps fine....
HELP!
Update (10/25/2016)
OK so I have put my old Battery Back in its at "Replace Soon" so should be OK. Fans seem to be going a little fast and all the time.
So the new battery, really not making much difference there.
So once I get it started, its all good, not sutting down.
So what is it? Something to do with starting up?
Help!
Это хороший вопрос?
Оценка 0
6 Комментариев
Did you spill anything on it?
из
Dont think so, but I have had it for 8 years so its possible! What would that mean?
из
i think there can be issue in the motherboard .
из
OK Lee thanx
из
u think its defo the logic board?
из
Показать 1 больше комментариев
Добавить комментарий
2 Ответов
Выбранное решение
Connect the power adapter to the Mac. On the MacBook / Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time. Release all keys and the power button at the same time – the little light on the MagSafe adapter may change colors briefly to indicate the SMC has reset.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Tried it not making any difference
из
Here's link to the Apple Support document that talks about what @mayer suggests.
Reset the System Management Controller (SMC) on your Mac
Оценка 1
1 Комментарий:
из
Добавьте свой ответ
paulnewhouse будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 1,287
