screen turn on and off when I touch the laptop lifebook s751
screen turning on and off when i touch the laptop mostly on the body, everything is working ok even when i touch the screen ,, so i dont think so its about screen.. i tried to open it up but all wires or sockets where in the right place.. so i wonder what it might be.. should i just change the main board?
what you think guys?
thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
first u need to check the connector cable from monitor to the board it's likely the issue here , maybe not connected well from both side u better check or corrupted need a replacement.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
i checked everything, i disassembled down to the main board, everything looks very ok. ports are solid, but when i push some where around to the CPU fan area picture will gone, and i have to shout down and turn on again. i tested the main board alone to be sure nothing is shorting between sink and main board, but still same result..
any idea?
Thanks
из
Добавьте свой ответ
frankdez будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 6
За всё время: 86
