The Samsung 5 Megapixel camcorder was released in 2011. It can be submerged in water up to a maximum of 3 meters and dropped from a maximum of 2 meters. It also records video in 1080P.
Why my camcorder won't turn on?
No matter what I do I cannot get the camcorder to turn on. I have charge it for several hours and even check the led on the side is lit when plugged in. The camcorder only has a little over a year and I have used it only a few time, so I don't think is the battery. ANY SUGGESTIONS ???
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Since you've tried charging it, you might have to change the screen display according to the trouble page for the device ( Samsung HMX-W200 Troubleshooting ).
Был ли этот ответ полезен?
Счет 0
Hello,
Since you stated you tried to charge your camcorder without any luck, you may have a faulty USB charging port. But do not worry as you can follow the guide here (Samsung HMX-W200 Troubleshooting).
Счет 0
Добавьте свой ответ
Antonio Abades Lescano буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 13
За всё время: 1,492
