had the same problem and was able to solve it:
I disassembled more or less the whole speaker (use the right screwdrivers, not to mess up the screws) following some youtube vids.
I found two problems for the buttons not working and solved them like this:
1) The flat cable connecting the buttons with the circuit board tends to slip out of its “gripper” on the PCB.
I slid it back in, closed the gripper and put a little tape on top
2) The Bluetooth button tends to get stuck, wich causes the power button not to work any more. To solve this I opened the ruber cover between PCB and outside cover. There is a white/transparent plastic piece attached below, that has the same function like a “rubber dome” in a keyboard. It has two little noses on its bottom to push on the buttons on the PCB (power and Bluetooth). I cut off a part of the bluetooths nose, to give the button on the PCB more space to come up again. Obviously dont cut off too much…
after reassembling everything works as it should again and Im happy.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
5 Комментариев
See My jbl flip 3 was working out really well but until after a while the turn on button stopped working. I can't even turn it on. What I usually do is plug it to my computer and it will turn on but know it won't even turn on. The battery is at 100% and I need it fixed. Anybody know how to fix this?
из Curtis
My jbl speaker Buttons not working
из Sahil Arora
How can fix it? I have this problem. Help pls
из Varbendi
I have the same problem to idk if it not charging or if it the buttons that dont work how can i fix it
из Dash20brave@gmail.com
Same problem but slightly different in my case it show only white light when i turn on power button no sound of power off/on, and button are not responding except power button but no sound. How to fix it please help
из samukalamdebbarma
