Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Overheating? wont make calls all-touch stops.
I had a customer bring in an iPhone 6 that gets very hot. I am wondering if its a lost cause, it turns on and stays on gets very hot the digitizer stops working, it wont make phone calls. its connected to wifi says service is there. i Tried a new battery and screen and the same thing still happens. i have checked their settings and nothing is set to stop calls. if anyone has any experience with this particular issue i would LOVE to know how you fixed it, or if its not fixable at all. THANK YOU
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Almost certainly board level damage. Usually due to water damage but it could have been due to a drop. Since multiple systems are not working, I'd lean towards water damage.
Был ли этот ответ полезен?
Оценка 1
overheating is probaly down to a damaged or loose ic
Оценка 0
1 Комментарий:
I went ahead and did a system restore and update, has cooled down since then, keeping an eye on it. will keep the ic chip in mind i know how those can be quite the problem
из
Добавьте свой ответ
Veronica Royal будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 116
