Flywheel removal to replace sheer key
I need to remove the flywheel on a Briggs and Stratton 5 hp engine to replace the sheer key. I have done this before, but I can't remember if the threads on the shaft are right hand or left hand. I have removed the cover and part of the pull cord start assembly. The body keeps the flywheel on and I have not been able to un screw it!
The engine is back firing through the carberator that I'd how I know it has jumped time.
Это хороший вопрос?
Оценка 0
1 Комментарий
Thank you! When the righty did not work, too tight I guess, I thought it was time to check with someone else. I will bear down this time!
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
smithron4 just checked on one of mine. "righty tighty lefty loosy" So CCW to loosen the nut should work
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
smithron4 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 288
