Why I have white vertical lines on the screen?
I'm using my ipad then white lines come out of nowhere. I have an image in this link (apple disscusion). Please help
Это хороший вопрос?
Это хороший вопрос?
Hi guys, I have had 36 clients approach me with the same problem. I saw no drop damage. Some are even so careful that I believe their iPad mini 2 and 3 never even witnessed a drop let alone a scratch. Bottom line is, I had to replace all their screen, the one underneath the touch glass. SO far none of the clients returned to me for complaints. I believe this is a hardware issue, a design flaw from Apple’s part. I also believe mini’s are plague’d with this white line problem.
Был ли этот ответ полезен?
I had this happen to my gen1 ipad many years ago. I took a chance and bought a no longer charging ipad gen1 that appeared to have a good screen on ebay. When I replaced the display the issue was fully resolved. I believe it is just the screen going bad sadly.
I also have this on my iPad Mini 2. I have had this iPad for two year now and it had just begun doing this last month. I think I should just get a new one.
I have found that putting the brightness on maximum reduces the chances of this happening. Sometimes I need to turn the screen off and on a few times.
I got rid of mine by having the “battery replaced” by Apple at the Apple Store. In this “repair” the whole device gets replaced with a new device. It solved a bunch of my problems, including a stuck Home button.
За последние 24часов: 4
За последние 7 дней: 8
За последние 30 дней: 15
За всё время: 10,035
6 Комментариев
This just happen to mine too.
I can get it to go away by locking the screen and unlocking, but it will fritz back again.
Mine, unlike yours, seem to keep in a horizontal direction. If I rotate the iPad, the lines rotate as well.
The reboot Apple logo is washed out.
I am really quite unhappy by this.
I wish I had an answer for you. But I don't yet.
I've factory reset the iPad, updated the firmware to 10.1.1, and restored.
It is still doing this.
What happened was that I connected my iPad to the Apple Lightening to HDMI connector with a suspect HDMI cable. I had used my regular HDMI cable the night before and it worked fine, but I found this longer one I had from my parents' place and tried to use it. I think maybe the cord did something to my iPad… maybe.
That's all I got for you. @jetaudiomedia, I hope you can figure this out too.
I "might" still have some extended warranty from my Visa on it, but we are talking mere days left.
из SkipR
Could you please post the link to your Apple Discussion group thread as well in case someone posts a possible answer/solution there? thx.
из SkipR
https://discussions.apple.com/thread/773...
из SkipR
Hi, as I posted on the Apple Discussion page, did you ever come to any resolution for this problem? What ended up being done?
из SkipR
Did you find a solution for this? I have this too !
из Anoud Nadir
Показать 1 больше комментариев
