Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
113вопросов Показать все
Can I put a logic board from a G3 12" 800 in a G3 14" 800?
I have a G3 14" 800 with a logic board that got fried around the power supply area. I also have a G3 12" 800 with a good logic board. Can I use the 12" board in the 14" case, or is there a problem with the battery connectors?
Also will it drive a 14" screen, or will it only use 12 size area?
Это хороший вопрос?
Оценка 1
Добавить комментарий
4 Ответов
Выбранное решение
You can! It's got the exact same form factor (the 14" uses a battery cable extension to get around the case size), and it will drive a 14" screen just fine (same resolution, bigger screen).
Был ли этот ответ полезен?
Оценка 2
As far as I am aware, other than the difficulty of lining up the ports and battery connector, it's possible.
Оценка 1
Someone who knows how to handle a solder iron could take off the battery connector from the 12" board and fix it to the 14" logic board.
Оценка 1
Thanks guys for your answers. Looks a rather complicated job (with 2 iBooks to take apart!) but the step by step instructions on ifixit are great. I'll do it over the next few days as the Christmas food wears off! Merry Christmas to all.
Оценка 0
Добавьте свой ответ
noel2 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,249
