Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2375вопросов Показать все
So I broke the antenna contact wire... now what?
So while I was taking apart my iPhone 4 (just for the fun of it) I didn't notice that the antenna contact wire was connected to the speaker/microphone assembly.
I was following this guide: iPhone 4 Teardown
And I got to step 12 when I yanked out the speaker and broke off the connector at the end of the wire.
The connector is nowhere to be found, and now my antenna wire connection is about 2 mm short off where it's supposed to connect with the main logic board.
Will attempting to solder this do any good? Should I see if Apple can repair this for $100 or so or what?
Thanks.
Это хороший вопрос?
Оценка -1
1 Комментарий
I don't know why I didn't even think about checking eBay for a replacement part. Look's like I can get one for about 10 dollars. Thanks!
из
Добавить комментарий
1 ответ
Выбранное решение
Apple doesn't do component-level repairs, so the only thing they can do for you is sell you a refurb. You're probably better off trying to get a replacement part (even if that means just waiting until more parts become available...)
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Blane Frye будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 2,395
