How do I reset the tv using a universal remote?
I have built in freeview and accidently changed it to analog channels and now cant change it back to freeview so i need to reset the tv using a total control universal remote?
Это хороший вопрос?
Это хороший вопрос?
Jodie, I am not familiar with your TV, so I did a search and this info. is all I found, hope it works for you.
Press and hold the (MENU) button on the side of the TV. The settings menu should appear. Continue to hold the menu button until this menu disappears.
TV should now go blank for a couple minutes, then revert to factory settings, and installation screen. Good luck.
Был ли этот ответ полезен?
I used one for all universal remote to reset my TCL smart TV. It depends on your TV model because the steps to reset for each model are different. What you can try is to press the reset button at the back of the TV to reset your device.
Please help i forgot my pin number for restricted profile? I need to unrestricted
If you are using some simple universal remotes like GE, just power recycling is enough. For this, remove the batteries from the compartment for a few minutes, then re-insert. You have to re-program again with the universal remote codes then.
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 31
За всё время: 3,426
