The Panasonic Lumix DMC-GF2 was released in 2011 and is a 12.1 megapixel mirror-less camera. The DMC-GF2 comes with an interchangeable lens system and a built-in flash system.
4вопросов Показать все
What might be causing the screen of my camera to be dim?
I can't see the pictures that I have taken because the screen is too dim. I can just barley make out that the screen is on, but I cant see anything on it. How do I fix this?
Это хороший вопрос?
Оценка 0
1 Комментарий:
student instruction/project
из
Добавить комментарий
1 ответ
Your camera's battery could almost be out. You'll need to charge it if that's the case!
Also, the screen could be broken. You may try replacing the LCD screen.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Nicole Gerlach будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 5
За последние 30 дней: 9
За всё время: 100
