panic(cpu 1 caller 0xffffff8000a7b028b)
Hi, i google this panic error line, and keeps popping up, i replaced the HDD, and i get the folder missing icon with another macbook pro that i have, but when i try to boot again with the same HDD i get this error line.
heres a picture of the error
but its not the OS, i set that HDD in another macbook pro 13" 2010 and its good i can log in with no problem
heres my toughts:
the flex cable of the hard drive must be replaced, or the logic board must be replaced, but im not sure
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
"panic cpu 1 caller" Unfortunately your cpu or another they of chip is failing. Replacement of your logic board is probably your best option.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
So the cpu 1 it's related to logic board failures?
из
i have the same problem went to install a different hard drive give me the same picture but if i used the hard drive that comes with the computer don't happen so the cpu is ok
из
Добавьте свой ответ
armandomh91 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 17
За всё время: 1,122
