The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
123вопросов Показать все
Purchase Apple Watch (42 mm) LCD Screen and Digitizer?
So i have a series 1, 42mm white apple watch. I bought it with a cracked screen. Now i'm looking to get the screen replaced and i have much practice replacing and fixing iDevices, so i'm comfortable doing this my self. But i cannot find a place to buy the 42mm LCD+Digitizer combo. I looked here on iFixit (my favorite go to website when needing help) but it says "Not for sale". Whats up with this? Does no one make replacements for the 42mm version? its there a legit way i can get a OEM replacement? Or a very good knock off?
Это хороший вопрос?
Оценка 3
Добавить комментарий
4 Ответов
Наиболее полезный ответ
Here is another supplier you can get it from lcd/digitizer assembly.
http://www.unionrepair.com/apple-watch-1...
Был ли этот ответ полезен?
Оценка 2
I had the same problem, and after weeks of searching the web I eventually bought an iCloud locked apple watch off eBay, since they're rather cheap (I got mine for about 100$). I would not recommend it 100% though, since iCloud locked devices have a high chance of being stolen.
I repaired mine in august and havent had any problems since, its a rather simple repair. I would recommend buying thin adhesive strips though, because my screen keeps loosening from the frame.
Hope I could help
Оценка 1
hi you can get a lcd screen and digitizer assembly here, very reasonable price
Оценка 1
Hey, you can purchase a good reliable lcd/screen display/digitizer for the Apple Watch 1 42mm Band at Repair Parts Plus. Here is the link! Also a very reasonable price! http://www.repairpartsplus.com/Glass-Tou...
Оценка 0
1 Комментарий:
Thanks! But is there somewhere with a lcd+digitizer combo? Because I haven't seen or heard of someone being successful in removing the digitizer to reuse the lcd since they are glued together.
из
Добавьте свой ответ
Benjamin Busath будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 8
За последние 30 дней: 10
За всё время: 4,119
