Need a diagram of 91 chevy c1500 steering column
Steering wheel is very loose . Took it apart and tightened it up and put back . Wll not go back together. Would like a diagram of steering column.
Это хороший вопрос?
Это хороший вопрос?
kpgklm, The links below will show exploded view and vids on steering column to aide in your repair. Check the attached links,instruction and guides, Good luck.
http://www.steeringcolumnservices.com/ex...
Был ли этот ответ полезен?
L Pfaff came thru with flying colors.. Very fast response with the info I needed. Thank you so much ! Still good people around !
kpgklm, thanks for the response, if it was the answer you needed vote it up, Thanks.
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 54
За всё время: 15,501
1 Комментарий
Make sure bearing is assembled properly just behind steering wheel
из p_buchwald
