Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
210вопросов Показать все
Use a display from the original Apple Watch for the Series 1?
Hey everyone.
I have recently broke my series 1 Apple Watch, and I am now looking for replacement Display-units. The device does still display things, just the glass is broken. I have found several ones, allthough they are all rather expensive. I just stumbled upon an auction for an original Apple Watch Display, which comes from the series 0 model. As its current price is relatively low, I'd like to bid as well.
I was wondering though: Is it possible to use the Display unit from an Apple Watch Series 0 for a Series 1? I does seem to have the same connectors, and I don't remember Apple mentioning any change of the Display when they issued the Series 1 Watch.
I would be really thankful for an answer to this problem, or at least some opinions.
Many thanks!
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
Выбранное решение
The display for the original Apple Watch and the series 1 can be interchanged as the only thing changed really was the processor speed. Ive also just doubled checked on here and both have the same screen/digitizer, Item Code: IF308-009
Hope this helps
Был ли этот ответ полезен?
Оценка 1
4 Комментариев:
Many thanks for your reply, I really couldn't find a way of figuring this out. I didn't know one could search for parts on here, but now I do.
Also by the way, do you know what the little cable on the back of a Watch display with the three small solder points does?
Thanks alot in advance
из
The cable on the back with the 3 small solder points connects the power supply to the proximity sensor.
из
Wow, I did not know this. I am going to order a completely new display unit anyway, but is it possible to desolder that cable without damaging it? Just something I want to try.
из
Yes it's possible to remove to cable without damaging it. Just apply a little heat to each point while slightly lifting the cable and it will come straight off (no need to apply any additional solder)
из
Добавьте свой ответ
Daniel будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 380
