Just an update to my last post. I took the machine apart again and using a can of air blasted all the dust out. I then checked all the connectors and made sure everything looked ok. I pulled the temperature sensor from the drive and the board and then reconnected it, ensuring that the connections were good. I reassembled the machine, plugged it in, and booted it up...same issue. However, my fan will eventually reach about 4.5k RPMs and stay there, not the 5k I reported earlier. Some things to note, the model# for this machine is EMC No 2374. All other fans, and temps, look normal. The HDD temp is at 38C, but the HDD fan is at 4524RPM. The drive I bought, following the guide, was the Seagate model# ST31000524AS. The drive that I pulled out of the machine was the ST31000528AS. The differences can be found here:
The ST31000524AS is a 6Gb/s drive whereas the ST31000528AS is 3GB/s:
Barracuda SATA Product Manual, Rev. A (ST31000524AS):
ST31000524AS
Barracuda 7200.12 Serial ATA Product Manual, Rev. C (ST31000528AS):
ST31000528AS
I went ahead and purchased the ST31000528AS from another site to see if that makes a difference. If it does, the step by step guide might need to reflect this information. I'll post an update once the other drive is installed. Some more system info:
Model Name: iMac
Model Identifier: iMac11,1
Processor Name: Intel Core i5
Processor Speed: 2.66 GHz
Number Of Processors: 1
Total Number Of Cores: 4
L2 Cache (per core): 256 KB
L3 Cache: 8 MB
Memory: 12 GB
Processor Interconnect Speed: 4.8 GT/s
Boot ROM Version: IM111.0034.B02
SMC Version (system): 1.54f36
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
