Repair guides and support for external portable storage by Western Digital including the My Book series, My Passport and others.
218вопросов Показать все
Why did my data disappear? How to recover lost data?
This 3.5" 1 TB WD Caviar Green HDD started to act strangely a little while ago when it started accessing files slower then normal...
On long copies it would stop with some error,
Eventually I got errors like original files not found.. The next thing I knew, the folder of interest (holding 3/4 of the content of the drive) was "empty", with "0Kb" of data and "0 files", a delete operation was never run by me, this happened after a failed copy operation...
I'd like to get some opinions on whether the drives problem is in the direction of hardware or software (corupt filesystem, bad sectors)
Thank you all,
This information is very important to me and since this is the backup, and my origional also died (for sure hardware) I have no other copies, and the situation really depresses me...
I'd also like to know if I have any hope of getting those lost files back, and what approach is best to take. Also, hypothetically if I was going to shell out a 1000$ for data recovery what are my chances of getting that 500GB of stuff back (at least some portion)?
Это хороший вопрос?
Оценка -1
2 Комментариев
Organizations like DriveSavers are expensive, but the good ones only charge if they recover your data. They have a very high success rate.
из
There's a link to them on my webpage.
из
Добавить комментарий
1 ответ
Выбранное решение
First tell us about the original machine and how it died, we may have a better chance on that one. Do you have another machine, if so what is it and what was the original machine and how big was the original hard drive? Also do you have any anti-virus software installed. What system are you running?
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
+ agreed
из
Добавьте свой ответ
Liam Speirs будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 1,131
