The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
56вопросов Показать все
truck stalling out while in gear only when breaking
what would make a ford f 150 die when i am off the gas peddle, guage comes on saying "check guage" , oil was low so i added and still having trouble keeping it running , no check engine light, can someone help
Это хороший вопрос?
Оценка 0
1 Комментарий:
Hi, Suggest you take it to an AutoZone shop and get a free OBDII scan check to see if there are any fault codes being registered. This may be the quickest way of finding out what is wrong. Is it rough idle when stationery for example?
из
Добавить комментарий
1 ответ
Alternator or maybe you vacuum but have you had to jump it lately?
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Arthur будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 49
