Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Touch ID not working
Hello there guys I recently bought an iPhone 6 off eBay which was smashed screen and when I received the item I see the Touch ID keeps saying Touch ID can't setup on this phone I contacted the seller he said it was working fine b4 but if I replace the LCD screen it will work back again so I decided to replace the LCD and keep the original metal shield and home button so the Touch ID will work but after I replaced it I see the Touch ID not working still saying the same thing can't setup Touch ID on this phone so I'm quiet frustrated do u guys have any solution for it? Any answer would b appreciated .thanks
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
If Touch ID did not work with the original , smashed screen, the you probably have a damaged home button Touch ID.
I would ask for a refund and send it back. Otherwise you will spend a lot of time and money troubleshooting and repairing this phone.
eBay will protect you from this kind of problem (some would say scam).
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thanks for ur answer
из
Добавьте свой ответ
Jay будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 257
