Дата выхода 25 сентября 2015 г. Модель A1688 / A1633. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
2690вопросов Показать все
iPhone 6s screen flickers after display replacement
I've repaired a couple iPhone 6s now, and a lot of the time the new screen flickers around the edges. Any ideas what's causing that?
I feel like it's something I'm doing, because I haven't found anyone reporting any issues on it. I would say 5 out of 6 6s repairs that I have done, seem to do this. Last one I did, the issue went away on it's own, but it's just a pain that it seems to happen every time I do this repair.
Any ideas why this happens?
Это хороший вопрос?
Оценка 3
2 Комментариев
Was the battery unplugged during the screen replacements? Have you tried turning the phone off and on repeatedly?
из
Can you post a pic? That does sound weird.
из
Добавить комментарий
2 Ответов
Выбранное решение
This happens all the time and is nothing to worry about it. I call it the static screen funness. Basically if you don't actually power the phone down and disconnect battery before installing or removing a screen this can happen. It will almost always go away on its own in about 1 hour. Sometimes leaving the phone off helps it go away quicker. Trust me nothing to worry about.
Был ли этот ответ полезен?
Оценка 7
1 Комментарий:
Hi
We should disconnect the battery and wait or all connector must be connected during that?
из
Try to replace a new screen, first of all you must tested before you move camera, finger etc. Make sure all safe and work before move it
Оценка 0
Добавьте свой ответ
patrickyoung1018 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 15,378
