iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904вопросов Показать все
Volume stuck at max
I have a 80GB iPod Classic and the volume is stuck at maximum. I can use the wheel and the display shows it going up and down but the volume is always at max and changing the volume limit doesn`t do anything. I have tried restoring it and resetting it several times and nothing makes a difference.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Hi,
Try plugging the device into an iPod dock or something that doesn't use the headphone jack to play the sound and test it there. If it still has the same issue it is possibly a damaged logic board. If you can adjust the sound normally there then it's likely an issue with the headphone jack / cable.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
T Radical будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 10
За всё время: 463
